Hi , I am getting An item with the same key has already been added. error . Here is my code.
<DockPanel x:Name="LayoutRoot"> <Grid> <igCA:XamChart HorizontalAlignment="Left" Name="XamChart1" VerticalAlignment="Top" > <igCA:XamChart.Axes> <igCA:Axis AxisType="PrimaryX"> <igCA:Axis.Label> <igCA:Label Format="{}{0:MMM-yyyy}" FontWeight="Bold"/> </igCA:Axis.Label> </igCA:Axis> <igCA:Axis AxisType="PrimaryY"> <igCA:Axis.Label> <igCA:Label Format="{} {0:C}" FontWeight="Bold"/> </igCA:Axis.Label> </igCA:Axis> </igCA:XamChart.Axes> </igCA:XamChart> </Grid> </DockPanel>
Using context = New MVEntities() Dim query = context.GetChartData(13).ToList Dim seriesUnitsInStock As New Series() seriesUnitsInStock.DataSource = query seriesUnitsInStock.DataMapping = "Value = Amt; Label = MonYr; ToolTip=Amt" Me.XamChart1.Series.Add(seriesUnitsInStock) End Using
query has two columns MonYr (1st day of the Month) & Amount.
Any idea how to resolve the error?
Thank you
I am using 2010 V 2. Ok i will try and let you know.
Which version of the WPF Chart are you using? Can you try applying the latest service releases? I believe we fixed an issue like this. If this doesn’t help, can you send us your project, because now we are not able to reproduce this issue?
Any thing wrong with the question? No one knows how to fix this?
