I am using the xamDataGrid and cannot view a window in expression blend 4
I get the following error message "the given assembnly name or codebase is invalid"
In VS2010 there is no such problem only in expression. The project is using .NET 4.0
Does anyone know what I can do about this? Its proving a nightmare to work around because I am using the xamDataGrid heavily in my project.
Thanks in advance
I know it has been a while since you posted this issue. I wanted to check if you are still expereincing this issue. If so, please let me know what version of NetAdvantage and which CLR you are using.
Valerie
