1024
combobox fiekd in xamdatagrid
Hi, I need to display one column in my xamdatagrid as combobox. So far what I did is: created a field with EdtorType of XamComboEditor
igDP:Field Name="SeconderyCode" Label="—…ƒ Ž™‰">                            <igDP:Field.Settings >        <igDP:FieldSettings AllowEdit="True" CellValuePresenterStyle="{StaticResource seconderyCodeBackgroundStyle}" EditorType="{x:Type dge:XamComboEditor}" > <igDP:FieldSettings.EditorStyle>        <Style TargetType="{x:Type dge:XamComboEditor}">                                                      <Setter Property="DropDownButtonDisplayMode" Value="Always"/>                                    <Setter Property="ItemsProvider" Value="{DynamicResourceComboEditorListSeconderyCode}"/>                                             <Setter Property="FlowDirection" Value="LeftToRight"/>                                                      <Setter Property="HorizontalAlignment" Value="Left"/>                                                      </Style>        </igDP:FieldSettings.EditorStyle>                                    </igDP:FieldSettings>        </igDP:Field.Settings>        </igDP:Field>        I attached the ItemsProvider as you can see to a dynamic resource which I supply in code:
ComboBoxItemsProvider ip = new ComboBoxItemsProvider();                                         DataTable dt = new DataTable();        dt.Columns.Add("ID", typeof(string));        dt.Columns.Add("Name", typeof(string));        dt.Rows.Add(new object[] { "", "".PadLeft(30) });                                                            dt.Rows.Add(new object[] { "NOHON", "ŒŒ€ „… "});                                                            dt.Rows.Add(new object[] { "ONLY", "Œƒ"});                                                            dt.Rows.Add(new object[] { "WITHOUT", "ŒŒ€"});                                                            dt.Rows.Add(new object[] { "MINUS", "™Œ‰Œ‰ "});                                                dt.Rows.Add(new object[] { "EXT", "Ž‰…‡ƒ"});                                                            ip.ItemsSource = dt.DefaultView;        ip.ValuePath = "ID";        ip.DisplayMemberPath = "Name";        this.Resources.Add("ComboEditorListSeconderyCode", ip);
        Now, the issue is that I don't want to show all of the items in each record. I wnat to be able to choose which items would be displayed and which aren't in run time according to a condition in the EditModeStarting event. How can I accompish this? By the way, I'm not sure at all that the code I wrote up until now is the most appropriate for my purpose. If you have another way you belive it should be accomplished, please, tell me. Thank U!
