910
Does DataCards Support auto create fields from PropertyDescriptors ?
Currently I have a custom data object that is bound to a XamDataGrid, I use PropertyDescriptors to define what field are in the custom data object.
The PropertyDescriptors will let the XamDataGrid that it has to create 7 Fields ( Columns ) even though pysically the data object only contains 2 public properties.
Basicly you can access the data on the custom object [XXX].
This has worked perfect in the XamDataGrid.
Does the DataCards support this functionality ?  If take the same data object and bind it to the xamDataCards, I only get the two public properties define on the data object instead of the 7 I would normally get in a XamDataGrid.
