In the XamDataChart We want to be able to only display the marker to which the mouse's x-coordinate is closest to. In other words, we want to visually track the current x-location along the chart.
This idea is similar to Google Finance. It displays a circle on the chart.
In the attached picture, obviously three circles are displayed - one for each stock.
Hope this makes sense. Thanks in advance.
Adam
Hi ,
It doesnt work accurately if there are lots of Y variations over short x interval (lots of points over short X interval), the reason i found was not all the markers are created for all the points... for example i have 400 pts in the chart, but Markers count in TrackingGrid Items is always 50, so I am not getting the accurate marker for a particulate point. I am using splineSeries... I tries setting UseHighMarkerFiedlity also but it doesnt help
Here, try this version instead. The other version has some issues with WPF, and this version is simpler:The Xaml:
<UserControl.Resources> <local:TestData x:Key="data1" /> <local:TestData x:Key="data2" /> <DataTemplate x:Key="customTemplate"> <local:TrackingGrid x:Name="trackingGrid" Series="{Binding Series}" VisibilityItem="{Binding ElementName=visibilityItem}"> <Ellipse x:Name="seriesMarker" Stretch="Fill" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Fill="Transparent" Stroke="Transparent" StrokeThickness="0.5" MinWidth="15" MinHeight="15" > </Ellipse> <local:VisibilityItem x:Name="visibilityItem" VerticalContentAlignment="Stretch" HorizontalContentAlignment="Stretch" Visibility="Collapsed"> <Ellipse Stretch="Fill" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Fill="{Binding ActualItemBrush}" Stroke="{Binding Series.ActualMarkerOutline}" StrokeThickness="0.5" MinWidth="15" MinHeight="15" > </Ellipse> </local:VisibilityItem> </local:TrackingGrid> </DataTemplate> </UserControl.Resources> <Grid x:Name="LayoutRoot" Background="White" > <ig:XamDataChart Name="xamDataChart1" MouseMove="XamDataChart_MouseMove"> <ig:XamDataChart.Axes> <ig:CategoryXAxis x:Name="xAxis" ItemsSource="{StaticResource data1}" > <ig:CategoryXAxis.LabelSettings > <ig:AxisLabelSettings Visibility="Collapsed" ></ig:AxisLabelSettings> </ig:CategoryXAxis.LabelSettings> </ig:CategoryXAxis> <ig:NumericYAxis x:Name="yAxis" > <ig:NumericYAxis.LabelSettings > <ig:AxisLabelSettings Visibility="Collapsed" ></ig:AxisLabelSettings> </ig:NumericYAxis.LabelSettings> </ig:NumericYAxis> </ig:XamDataChart.Axes> <ig:XamDataChart.Series> <ig:LineSeries x:Name="igLineSeries1" ItemsSource="{StaticResource data1}" XAxis="{Binding ElementName=xAxis}" YAxis="{Binding ElementName=yAxis}" ValueMemberPath="Value" MarkerType="Diamond" MarkerTemplate="{StaticResource customTemplate}"/> <ig:LineSeries x:Name="igLineSeries2" ItemsSource="{StaticResource data2}" XAxis="{Binding ElementName=xAxis}" YAxis="{Binding ElementName=yAxis}" ValueMemberPath="Value" MarkerType="Circle" MarkerTemplate="{StaticResource customTemplate}"/> </ig:XamDataChart.Series> </ig:XamDataChart> </Grid>
And the code behind:
public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); } private void XamDataChart_MouseMove(object sender, MouseEventArgs e) { XamDataChart chart = sender as XamDataChart; if (chart == null) { return; } foreach (var series in chart.Series) { var seriesPos = e.GetPosition(series); if (seriesPos.X >= 0 && seriesPos.X < series.ActualWidth && seriesPos.Y >= 0 && seriesPos.Y < series.ActualHeight) { SelectClosest( series, seriesPos); } } } private static IEnumerable<DependencyObject> VisualDescendants( DependencyObject obj) { for (int i = 0; i < VisualTreeHelper.GetChildrenCount(obj); i++) { var child = VisualTreeHelper.GetChild(obj, i); yield return child; foreach (var subChild in VisualDescendants(child)) { yield return subChild; } } } public static void SelectClosest(Series series, Point point) { double minDist = double.PositiveInfinity; TrackingGrid closest = null; FrameworkElement closestContent = null; FrameworkElement beforeVisible = null; foreach (var grid in TrackingGrid.Items() .Where((i) => i.Series == series)) { double left = GetLeft(series, grid.Item); double dist = Math.Abs(point.X - left); var content = grid.VisibilityItem; if (content != null && content.Visibility == Visibility.Visible) { beforeVisible = content; content.Visibility = Visibility.Collapsed; } if (dist < minDist) { minDist = dist; closest = grid.Item; closestContent = content; } } if (closest != null) { if (closestContent != null) { closestContent.Visibility = Visibility.Visible; } } else { if (beforeVisible != null) { beforeVisible.Visibility = Visibility.Visible; } } } private static Marker FindMarker( FrameworkElement item) { while (item != null) { if (item is Marker) { return item as Marker; } item = VisualTreeHelper.GetParent(item) as FrameworkElement; } return null; } private static double GetLeft( Series series, FrameworkElement item) { Marker m = FindMarker(item); if (m == null) { return double.NaN; } if (m.Visibility == Visibility.Collapsed) { return double.NaN; } TranslateTransform t = m.RenderTransform as TranslateTransform; if (t == null) { return double.NaN; } return t.X + m.ActualWidth / 2.0; } } public class TrackingGrid : Grid { public static readonly DependencyProperty SeriesProperty = DependencyProperty.Register( "Series", typeof(Series), typeof(TrackingGrid), new PropertyMetadata(null, (o, e) => { (o as TrackingGrid) .OnSeriesChanged(e); })); private void OnSeriesChanged( DependencyPropertyChangedEventArgs e) { Refresh(); } public Series Series { get { return (Series)GetValue(SeriesProperty); } set { SetValue(SeriesProperty, value); } } public static readonly DependencyProperty VisibilityItemProperty = DependencyProperty.Register( "VisibilityItem", typeof(VisibilityItem), typeof(TrackingGrid), new PropertyMetadata(null, (o, e) => { (o as TrackingGrid) .OnVisibilityItemChanged(e); } )); private void OnVisibilityItemChanged( DependencyPropertyChangedEventArgs e) { Refresh(); } public VisibilityItem VisibilityItem { get { return (VisibilityItem)GetValue(VisibilityItemProperty); } set { SetValue(VisibilityItemProperty, value); } } public TrackingGrid() { this.Loaded += TrackingGrid_Loaded; this.Unloaded += TrackingGrid_Unloaded; } private void Refresh() { if (_items.ContainsKey(this)) { _items.Remove(this); } _items.Add(this, new ItemInfo() { Series = Series, Item = this, VisibilityItem = VisibilityItem }); } void TrackingGrid_Unloaded(object sender, RoutedEventArgs e) { _items.Remove(this); } void TrackingGrid_Loaded(object sender, RoutedEventArgs e) { Refresh(); } public class ItemInfo { public Series Series { get; set; } public TrackingGrid Item { get; set; } public VisibilityItem VisibilityItem { get; set; } } private static Dictionary<TrackingGrid, ItemInfo> _items = new Dictionary<TrackingGrid, ItemInfo>(); public static IEnumerable<ItemInfo> Items() { return _items.Values; } } public class VisibilityItem : ContentControl { } public class TestDataItem { public string Label { get; set; } public double Value { get; set; } } public class TestData : ObservableCollection<TestDataItem> { private static Random rand = new Random(); public TestData() { double curr = 0; for (int i = 0; i < 1000; i++) { if (rand.NextDouble() > .5) { curr += rand.NextDouble(); } else { curr -= rand.NextDouble(); } Add( new TestDataItem() { Label = i.ToString(), Value = curr }); } } }
Hope that helps!-Graham
This solution depends on the crosshair event so make sure you have made the crosshairs visible but hidden. Also make sure the behavior is attached in the xaml like I did above.
-Graham
Thanks for the code. I'm having a hard time getting it to work. When I run it, I see the data and series, but no marker appears when I mouse over it. I have put breakpoints on teh OnValue2changed and OnValue1Changed methods, and they are never called.
I am interested in this more elegant solution.
Thank you for the answer. I will try it out when I get a chance. It appears more elegant than the solution that I used. I added a "dot" marker to the Series.RootCanvas.Children, and am positioning it on the canvas by using the GetScaledValue and GetUnscaledValue methods. Thank you!
