630
xamChart managing animation is procedule code
Hi there
I am creating and binding series in procedule code, just to a data table. I like the animations used in the Feature browser, I am not sure how to manage this in the code behind. I try this below but it doesnt work but struggled to find source code example
c1.Animation.BeginTime =
TimeSpan.Parse("00:00:00.25");
c1.Animation.Duration =
new Duration(TimeSpan.Parse("0:0:03"));
c1.Animation.AccelerationRatio = 0.5;
c1.Animation.DecelerationRatio = 0.5;
Where c1 is a series object
Thanks in advance
  • 27093
    Verified Answer
    Hello Chris,
    I have been looking into your code snippet and think I have found the problem. When setting properties in the code behind you need to explicitly instantiate your values likes so:    c1.Animation = new Animation();   which is actually the equivalent of its xaml counterpart the empty Animation node <igCA:Animation …
    I tested your code snippet with this addition and it worked ok.
    Please let me know if you require any further assistance on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
  • 9836
    Verified Answer
    You can try to set a new instance to the Animation property of the Series e.g:
    c1.Animation = new Infragistics.Windows.Chart.Animation()
                    BeginTime = TimeSpan.FromSeconds(1),
                    Duration = TimeSpan.FromSeconds(3),
                    AccelerationRatio = 0.5,
