300
XAMDATAGRID - Get value of Field
When  XAMDATAGRID is loaded at that time we have applied below style…
  <Style x:Key="cvpGrayWithTick" TargetType="igDP:CellValuePresenter">
            <Setter Property="Background" Value="#FFF3F3F3"/>
            <Setter Property="BorderBrush" Value="Gray"/>
            <Setter Property="BorderThickness" Value="0,0,1,0"/>
            <Setter Property="Template">
                <Setter.Value>
                    <ControlTemplate TargetType="igDP:CellValuePresenter">
                        <Border Background="#FFF3F3F3" BorderBrush="Gray" BorderThickness="0,0,0.5,0" HorizontalAlignment="Stretch">
                            <Grid Background="Transparent" HorizontalAlignment="Stretch">
                                <ContentPresenter Margin="5,0,0,0" VerticalAlignment="Center"/>
                                <Image Visibility="Hidden" x:Name="imgTick" Source="..\Images\icons_tick.png" Stretch="Uniform" Width="12" Height="12" HorizontalAlignment="Right" VerticalAlignment="Center"  Margin="0,0,5,0"/>
                            </Grid>
                        </Border>
                    </ControlTemplate>
                </Setter.Value>
            </Setter>
        </Style>
Now…when user click on the button then I need to check all CELL of record(0)  and if cell contain value then we need to display image else image should be Invisbile.
How I can get value of filed.
this.grdMerge.Records[0].FieldLayout.Fields[5]…
  • 69686
    Verified Answer
    You need to cast the Record[0] record to DataRecord. The DataRecord itself exposes the Cells collection and from there you can iterate through the cells and check their values.
    Hope this helps.
