630
changing a CellValuePresenterStyle at runtime
Hi
I have managed to work out (thanks to examples) how to change a cells background, and other properties based on data trigger. Conditional formatting etc...
I have an unbound field that displays an image. Based on a cell value I wish to either change the image or change the cellValuePresenterStyle to point to another style. For example is cell value = x then use cellpresenterstyle x, if y then use cellpresenterstyle y
The code looks messy in this here but no so if you take it out and into VS
I have this xaml for the unbound field:
<Style TargetType="{x:Type igDP:CellValuePresenter}" x:Key
="UserImage1">
<Setter Property
="Template">
<Setter.Value
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter
<Grid Width="50" Height
="50">
<Image
Margin="0"
HorizontalAlignment
="Center"
VerticalAlignment
="Top"
Source="{StaticResource BuddyBlue}" Width="50" Height
="50"/>
</Grid
</ControlTemplate
</Setter.Value
</Setter
</Style
This is my unbound field xaml from the grid:
<igDP:UnboundField Name="UserImage" Label
="UserImage">
<igDP:Field.Settings
<igDP:FieldSettings CellMinWidth="50" CellWidth="50"
CellValuePresenterStyle="{StaticResource UserImage1
</igDP:Field.Settings
</igDP:UnboundField
This is how I manage my changes to the foreground and background properties:
public
winUsers()
InitializeComponent();
Title =
"Users"
xamDataCarousel1.DataSource = GetUsers().DefaultView;
xamDataCarousel1.FieldLayoutInitialized +=
new EventHandler<Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs
>(xamDataCarousel1_FieldLayoutInitialized);
void xamDataCarousel1_FieldLayoutInitialized(object sender, Infragistics.Windows.DataPresenter.Events.FieldLayoutInitializedEventArgs
e)
//Get the CarName field
Field idField = e.FieldLayout.Fields["Name"
//Create the style in code behind
Style s = new Style(typeof(CellValuePresenter
//Create DataTrigger
DataTrigger trigger1 = new DataTrigger
//Create a Setter
Setter setter1 = new Setter(CellValuePresenter.BackgroundProperty, Brushes
.Red);
Setter setter2 = new Setter(CellValuePresenter.ForegroundProperty, Brushes
.White);
//Create a Binding
Binding binding = new Binding("Cells[SomeValue].Value"
//Set the trigger properties
trigger1.Value =
"X"
trigger1.Binding = binding;
//Add the setter in the trigger
trigger1.Setters.Add(setter1);
trigger1.Setters.Add(setter2);
//Add the trigger in the style
s.Triggers.Add(trigger1);
idField.Settings.CellValuePresenterStyle = s;
