When using the xamDialogWindow with IsModal set to true, tabbing between the controls in the dialog does not work. I've included xaml.
<UserControl x:Class="WpfApplication1.BaseWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:ig="http://schemas.infragistics.com/xaml" > <Grid > <ig:XamDialogWindow Width="300" Height="300" Header="Test" Name="xamDialogWindow1" StartupPosition="Center" IsModal="True" IsTabStop="False"> <Grid Margin="3,3,3,3"> <Grid.RowDefinitions> <RowDefinition Height="Auto"></RowDefinition> <RowDefinition Height="Auto"></RowDefinition> <RowDefinition Height="Auto"></RowDefinition> <RowDefinition Height="Auto"></RowDefinition> </Grid.RowDefinitions>
<TextBox Height="23" HorizontalAlignment="Left" Name="textBox1" VerticalAlignment="Top" Width="120" Margin="3,3,3,3" /> <TextBox Height="23" HorizontalAlignment="Left" Name="textBox2" VerticalAlignment="Top" Width="120" Grid.Row="1" Margin="3,3,3,3"/> <TextBox Height="23" HorizontalAlignment="Left" Name="textBox3" VerticalAlignment="Top" Width="120" Grid.Row="2" Margin="3,3,3,3"/> <StackPanel Orientation="Horizontal" Grid.Row="3" Margin="3,3,3,3"> <Button Content="Button" Grid.Row="3" Height="23" HorizontalAlignment="Left" Name="button1" VerticalAlignment="Top" Width="75" IsDefault="True" /> <Button Content="Button" Grid.Row="3" Height="23" HorizontalAlignment="Left" Name="button2" VerticalAlignment="Top" Width="75" IsCancel="True" /> </StackPanel> </Grid> </ig:XamDialogWindow> </Grid></UserControl>
HI,
This issue should be resolved by the latest service release.
If you have further questions regarding this issue, please let me know.
Sincerely, Matt Developer Support Engineer
Thanks for your response. It does work if modal is off, as I suppose you noticed.
I tested your sample code and reproduced your issue.
I will submit this for Developer Review.
Sincerely,
MattDeveloper Support Engineer
