45
Repainting problems while resizing tile?
We seem to have a problem with the Infragistics Tiles control, where the resize of a tile may leave
artifacts in its wake. The example program that we have supplied demonstrates this in the simplest
possible manner.
Steps to reproduce:
1. Run the example program. You will find there are two tiles, one containing a button labeled 'A
button', and one containing a label reading 'Hello world'.
2. Maximize te 'Hello world' tile.
3. Click the button labeled 'A button' in the other tile. Note that nothing will happen because nu
action has been associated with the button, but it should now have focus, as indicated by the
'dotted' rectangle inside it.
4. Click on the maximze button of the tale containing the button. Be sure to quickly move the mouse
pointer away from that position during the animation, preferably out of the program window
entirely.
5. Note that, while the tile with the button has resized and moved, the focus rectangle has not.
The ghost of the focus rectangle can be made to disappear by moving over one of tiles' title bar
buttons. You may find it possible to reproduce a similar problems in multiple ways. Essentially,
this effect seems to be triggered by maximizing a tile and then making sure that the mouse pointer
is not over any of the tile title bar buttons as the animation finishes.
In our actual application we see this effect not only with the focus rectangle, but also with an
adorner that we use. While the effect of an adorner floating somewhere where it should not be
concerns us more than the focus rectangle, we suspect that both effects have the same or similar
cause, and we choose this example to keep it as simple as possible.
Thanks in advance,
Dave
IGTilesDemo.rar
