2815
Creating an unbounded field with button bound to ViewModel command
Guys,
This is a snippet from a Style I need to modify such that the button's command property is bound to an element of IDictionary<string, ICommand> exposed by the ViewModel.
<Setter Property
="Template">
<Setter.Value
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter
<igWindows:CardPanel Width="{TemplateBinding Width}" Height="{TemplateBinding Height
<Button Style="{DynamicResource btnRemove}" Width="14" Height="14"
Content="{TemplateBinding Content}"
CommandParameter="{Binding ViewID
Command="{Binding Commands[AcknowledgeErrorCmd]}" />
</igWindows:CardPanel
<ControlTemplate.Triggers
<Trigger Property="HighlightAsPrimary" Value
="True"/>
<Trigger Property="IsFieldSelected" Value
="True"/>
<Trigger Property="IsSelected" Value
="True"/>
<Trigger Property="IsActive" Value
="True"/>
<Trigger Property="IsMouseOver" Value
="True"/>
</ControlTemplate.Triggers
</ControlTemplate
</Setter.Value
</Setter
Problem is, the binding is not working.
Now, if I replace the button with a TextBlock with the following binding:
<TextBlock Text="{Binding ElementName=root, Path
=DataContext.ViewID}"/>
I get DataItem.ToString() displayed, where DataItem is an instance of my data class.
Can you please help me understand where the disconnect is from CellValuePresenter to my main view?
TIA,
Klaus
