How can I hide the grid lines of a XamChart?
Jens
Hello Stefan,
I do this but only remove the background lines not remove the lines that i highlight in image. My xaml is
<ig:XamChart x:Name="chart" View3D="True" MouseMove="chart_MouseMove" MouseWheel="chart_MouseWheel" Background="Black" StartPaletteBrush="Red" EndPaletteBrush="Green"> <ig:XamChart.Transform3D> <RotateTransform3D> <RotateTransform3D.Rotation> <AxisAngleRotation3D Angle="10" Axis="0,0,0"/> </RotateTransform3D.Rotation> </RotateTransform3D> </ig:XamChart.Transform3D> <ig:XamChart.Scene> <ig:Scene MarginType="Percent" Margin="0, 15, 5, 0" Scene3DBrush="Transparent" Scene3DThickness="0"> </ig:Scene> </ig:XamChart.Scene> <ig:XamChart.Legend> <ig:Legend MarginType="Percent" Margin="80,0,0,0" Foreground="White"/> </ig:XamChart.Legend> <ig:XamChart.Axes> <ig:Axis AxisType="PrimaryX"> <ig:Axis.Label> <ig:Label Foreground="White"/> </ig:Axis.Label> <ig:Axis.MajorGridline> <ig:Mark Visible="False"/> </ig:Axis.MajorGridline> </ig:Axis> <ig:Axis AxisType="PrimaryY"> <ig:Axis.Label> <ig:Label Foreground="White" Format="{}{0:p2}"/> </ig:Axis.Label> <ig:Axis.MajorGridline> <ig:Mark Visible="False"/> </ig:Axis.MajorGridline> </ig:Axis> </ig:XamChart.Axes> <ig:XamChart.Series> <ig:Series ChartType="Column" DataSource="{Binding ChartContext.Source}" Label="{Binding Path=ChartContext.Name, UpdateSourceTrigger=PropertyChanged, Mode=TwoWay}" DataMapping="Value=Price;Label=Indicator" /> </ig:XamChart.Series> </ig:XamChart>
These lines are prominent when we rotate it, and i want to display YAxis and legend values in a tool-tip on mouse over on the chart series. See my sample for better understanding.
Hello Abu,
You can set the XamChart's Scne's Scene3DBrush Property to Transparent like this:
Also I believe that here:
http://ko.infragistics.com/community/forums/p/75930/385039.aspx#385039
Krasimir already do this for you.
Hope this helps you.
Hi All,
I want to remove xamchart 3d view shades from XAxis and YAxis. See attached image i highlighted the area that i want to remove. Kindly give me a feed back as soon as possible.
To disable Gridlines the Visible property of the Mark has to be set to False. Please, use the following sample:
<igCA:XamChart View3D="False" x:Name="chart" > <igCA:XamChart.Series> <igCA:Series ChartType="Column"> <igCA:Series.DataPoints> <igCA:DataPoint Value="3" Fill="#FFD70005" Label="Italy"/> <igCA:DataPoint Value="5" Fill="#FF6CA224" Label="Spain"/> <igCA:DataPoint Value="4" Fill="#FF076CB0" Label="France"/> <igCA:DataPoint Value="7" Fill="#FFE6BE02" Label="China"/> <igCA:DataPoint Value="5" Fill="#FF543792" Label="Portugal"> </igCA:DataPoint> </igCA:Series.DataPoints> </igCA:Series> </igCA:XamChart.Series> <igCA:XamChart.Legend> <igCA:Legend/> </igCA:XamChart.Legend> <igCA:XamChart.Axes> <igCA:Axis AxisType="PrimaryY"> <igCA:Axis.MajorGridline> <igCA:Mark Visible="False"/> </igCA:Axis.MajorGridline> </igCA:Axis> </igCA:XamChart.Axes> <igCA:XamChart.Scene> <igCA:Scene> <igCA:Scene.GridArea> <igCA:GridArea BorderBrush="#FF000000"/> </igCA:Scene.GridArea> </igCA:Scene> </igCA:XamChart.Scene> </igCA:XamChart>
GoranS
