I have a XamTabManager that I am using data triggers in a local style to hide one of the tabs. This causes the theme to be overriden. Do I need to used based on something to get the current theme?
Second, the tab header is all that gets hidden. How do I force the tab in view through xaml?
<igWindows:TabItemEx Header="Item View" Name="tabItemView">
<igWindows:XamTabControl x:Name="tabEditViews" Grid.Row="1" TabStripPlacement="Top" TabLayoutStyle="SingleRowJustified" Theme="[current]" Margin="0" > <igWindows:TabItemEx Header="Item View" Name="tabItemView"> .... </igWindows:TabItemEx> <igWindows:TabItemEx Name="tabOfficialCheck" Header="Official Check" > <igWindows:TabItemEx.Style> <Style TargetType="{x:Type igWindows:TabItemEx}"> <Style.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=DataContext}" Value="{x:Null}" > <Setter Property="igWindows:TabItemEx.Visibility" Value="Hidden" /> </DataTrigger> <DataTrigger Binding="{Binding Path=IsOfficialCheck}" Value="True" > <Setter Property="igWindows:TabItemEx.Visibility" Value="Visible" /> </DataTrigger> <DataTrigger Binding="{Binding Path=IsOfficialCheck}" Value="False" > <Setter Property="igWindows:TabItemEx.Visibility" Value="Hidden" /> </DataTrigger> </Style.Triggers> </Style> </igWindows:TabItemEx.Style> </igWindows:XamTabControl>
