Hi
I am using Infragistics tools volume 1 2010. Well I am facing a problem while loading and saving grid customizations as discussed for early versions as well in the following thread http://community.infragistics.com/forums/p/32603/178359.aspx . Its already known Issue but didnt find any fix for it.
Well Problem is that I am composing my field with a slider control and reposition the column and try to save it. Its working fine till saving but on load customizations my Control composed field moves to the end of the grid. Did anyone find the solution of the problem, or anyone could suggest some solution in this regard.
