I am trying to enable Ribbon tabs based Dock pane focus. Currently, I'm setting XamRibbon.SelectedTab in the GotFocus event handler of a TabGroupPane.
It seems to work, but only part of the time. Two questions:
1) This is probably a well-established pattern. I'm I doing it wrong?
2) Is there a Commands-based approach?
Hello Douglas,
I have been reading through your request and assume you are trying to make consistent RibbonTabs based for each pane like in MS Office. You can achieve such functionality by using the XamDockManager’s ActivePaneChanged event and ActivePane property along with the XamRibbon’s SelectedTab property and the RibbonTabItem events.
Please let me know if you require any further assistance on the matter or if I misunderstood our requirement.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
