I am trying to do the export in a background worker.
Does anyone have this working? What are the tricks to get it to work.
I implemented it the simple way with a backgroundworker, DoWoker,,,and I get an exception associated with TSA...
Any clues would be appriciated.
There is asynchronous support in the DataPresenterExcelExporter and DataPresenterWordWriter that was added in NA 11.1. You would use one of the ExportAsync overloads instead of the Export overloads. It is important to note that this is still done on the UI thread since it is dealing with objects that have thread affinity (e.g. the source grid and likely the datasource too) but the work is broken up to avoid locking the UI thread. The AsyncExportDuration determines the amount of time that will be spent exporting for each time slice and the AsyncExportInterval determines the amount of time to wait in between each time slice.
Hi !
I'm encoutering the same issue : no way to do an asychronous excel export. XamDataGrid is locked up.
To you have any news about the asynchrnous exporting ?
Yes, there is a plan that we have Asynchronous exporting in separate thread in the future.
Is there a plan to allow Excel Exporting in a separate theread, without these work arounds?
HI,
I agree with your workarounds. In a BackGround Worker threa,d create the Excel Workbook using the DataSource. Here a help link to our Excel Engineer
http://help.infragistics.com/NetAdvantage/WPF/2010.3/CLR4.0/?page=WPF_Infragistics_Excel_Engine.htmlSincerely,
MattDeveloper Support Engineer
