2815
using ValueConstraint with binding
I have this XAML:
<igEditors:XamNumericEditor Grid.Column="6" Margin="6,1,0,1" Grid.Row="1" Style="{StaticResource XamLongEditor}" Value="{Binding LogIdEnd, Mode=TwoWay}" Grid.ColumnSpan="1" IsEnabled="{Binding ElementName=UseLogIdEnd, Path=IsChecked, Mode=OneWay}" >
<igEditors:XamMaskedEditor.ValueConstraint><igEditors:ValueConstraint MinInclusive="{Binding LogIdStart, Mode=OneWay}"/></igEditors:XamMaskedEditor.ValueConstraint></igEditors:XamNumericEditor>
where LogIdStart is the value I want to be used as minimum.  When I change LogIdStart, MinInclusive constraint is not enforced based on LogIdStart.
What am I missing?
  • 2815
    This seems to be a common request so why don't you just add Min and Max dependency properties like so?
    public class XamNumberEditor :
    XamNumericEditor
    public object
    MinValue
    get { return
    GetValue(MinValueProperty); }
    set { SetValue(MinValueProperty, value
    public static readonly DependencyProperty
    MinValueProperty =
    DependencyProperty
    .Register(
    "MinValue"
    typeof(object
    typeof(XamNumberEditor
    new UIPropertyMetadata(null
    , MinValueChangedCallback));
    static void MinValueChangedCallback(DependencyObject depObj, DependencyPropertyChangedEventArgs
    e)
    (depObj
    as XamNumberEditor
    ).OnMinValueChanged();
    protected void
    OnMinValueChanged()
    if (ValueConstraint == null
    ValueConstraint =
    new ValueConstraint
    ValueConstraint.MinInclusive = MinValue;
    public object
    MaxValue
    get { return
    GetValue(MaxValueProperty); }
    set { SetValue(MaxValueProperty, value
    MaxValueProperty =
    DependencyProperty
    .Register(
    "MaxValue"
    typeof(object
    , MaxValueChangedCallback));
    static void MaxValueChangedCallback(DependencyObject depObj, DependencyPropertyChangedEventArgs
    e)
    (depObj
    as XamNumberEditor
    ).OnMaxValueChanged();
    protected void
    OnMaxValueChanged()
    ValueConstraint =
    new ValueConstraint
