260
How Best to Bind this DataSet?
I have a list of objects that needs to be bound to a grid.  However, the default "behavior" is not what I need right now.
My object DataItem contains descriptive properties, and then a collection of 2 different DataSourceItems.  By default these DataSourceItems appears as a child of the DataItem in the grid.  What I would like to see is the properties of these 2 items appear in the same row as the DataItem which is bound to the grid, not as children.
Simplified object structure is as follows:
class DataItem
public int id { get; set; }
public List<DataSourceItem> List { get; set }
class DataSourceItem
public string Name { get; set; }
public string Value { get; set; }
Any suggestions would be great, let me know if this is overly vague.
  • 69686
    To achieve this you would have to use UnboundFields which can work with indexers.
    You should use the BindingPath property of the UnboundField and set it to something like:
     BindingPath="PropertyName[index].PropertyName"
    example : BindingPath="List[X].Name"
    In addition to this, please make sure that the AutoGenerateFields property of the FieldLayoutSettings is set to false and you define the field layouts manually.
