Hello Infragistics.
Is there any way to export a XamDataGrid to a PDF document? Any help appreciated.
Thanks!
As for now we only export to XPS since this is the only supported format as of now for WPF. What you can do is use the Reporting engine to export to XPS and then use a converter of some sort to get the result you wanted. You can find such open source projects on the web.
Hope this helps.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
