I am using the documented way of using IsScrollTipField and IsPrimary and it works/compiles but after the compilation is done I get an error saying the the properties are read only and cannot be set to True.
Am I missing something here or why might this happen? Is there a new/better way of doing this? I can show you my XAML, but I won't post it unless you need it cuz it's pretty big.
Good to know. It is probably something in my environment. I just needed to check to make sure I wasn't messing things up!
I'm not sure why you are seeing that. I looked at the code and we aren't throwing that exception in those property setters.
