After the user changed the layout/configuration of the TabGroupPane and created some ContentPanes in many TabGroupPanes, how to programmatically consolidate ContentPanes in multiple TabGroupPanes into one TabGroupPane?
Thank you for the link. I still can't make it work. Here is my code snip:
public
class ContentPaneFactory : Infragistics.Windows.Extensions.
ContentPaneFactory
public ContentPaneFactory()
ConsolidateCommand =
new DelegateCommand(Consolidate, CanConsolidate);
GlobalCommands.ConsolidateTabsCommand.RegisterCommand(ConsolidateCommand);
#region
ConsolidateCommand
public DelegateCommand ConsolidateCommand { get; private set; }
private void Consolidate()
if (_target is DocumentContentHost
DocumentContentHost dch = _target as DocumentContentHost;
for (int i = dch.Panes.Count - 1; i >= 0; i--)
SplitPane sp = dch.Panes[i];
ConsolidateSplitPane(sp);
else if (_target is SplitPane
SplitPane sp = _target as SplitPane;
protected void ConsolidateSplitPane(SplitPane sp)
TabGroupPane tgpKeep = sp.Panes[0] as TabGroupPane
for (int j = 1; j < sp.Panes.Count; j++)
TabGroupPane tgp = sp.Panes[j] as TabGroupPane;
for (int
k = 0; k < tgp.Items.Count; k++)
ContentPane cp = tgp.Items[k] as ContentPane;
tgp.Items.RemoveAt(k);
tgpKeep.Items.Add(cp);
private bool
CanConsolidate()
return true;
#endregion
Not sure if I understand correctly about the visual tree.
Frank
HI,
I am just following up on this forum thead.
Do you need further assistance regarding this issue?
If you do, please let me know.
Sincerely, MattDeveloper Support Engineer
HI Frankwwu,
I have code snippet below that will consolidate contentpanes from one group to another.
Here a help link on TabGroups:
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=InfragisticsWPF4.DockManager.v10.2~Infragistics.Windows.DockManager.TabGroupPane.html
private void Button_Click(object sender, RoutedEventArgs e)
for (int i = tg2.Items.Count - 1; i > -1; i--)
ContentPane cp = (ContentPane) tg2.Items[i];
tg2.Items.RemoveAt(i);
tg1.Items.Add(cp);
Sincerely, Matt Developer Support Engineer
