710
Using a simple XML file or a DataTable as FlatDataSource
I am trying to use a simple DataTable  or an XML file (generated by another application) as a FlatDataSource for the xamPivotGrid. This should be easy I assume but I do not manage to have it work.
Using the following code doesn not make it (dt is my DataTable)
 FlatDataSource flatDataSource = new FlatDataSource()
               ItemsSource = dt.AsEnumerable().ToList()
Measures = XmlaDataSource.GenerateInitialItems("AmountOfSale")*/
I want something very simple to plug any Table to the xamPivotGrid. I cannot define a priori a class to serialize the dataTable (or XML file) so it is not so obivious to create the IEnumerable. Thanks for your help.
