75
ButtonTool BitmapImage IsFrozen Error
When the ButtonTools in our application change Enabled status, meaning the images will change gray/color, then we get the following error. The BitmapImages are not set to IsFrozen by us so I think the ButtonTool is doing it.
[2010-08-12 08:57:52,078] [1] ERROR ALMobile.Client.App - An unhandled exception has occurred: System.InvalidOperationException: Specified value of type 'System.Windows.Media.Imaging.BitmapImage' must have IsFrozen set to false to modify.
   at System.Windows.Freezable.WritePreamble()
   at System.Windows.Freezable.remove_Changed(EventHandler value)
   at System.Windows.ResourceReferenceExpression.ResourceReferenceExpressionWeakContainer.RemoveChangedHandler()
   at System.Windows.ResourceReferenceExpression.ResourceReferenceExpressionWeakContainer.InvalidateTargetSubProperty(Object sender, EventArgs args)
   at System.Windows.Freezable.FireChanged()
   at System.Windows.Freezable.Freeze(Boolean isChecking)
   at System.Windows.PropertyMetadata.DefaultFreezeValueCallback(DependencyObject d, DependencyProperty dp, EntryIndex entryIndex, PropertyMetadata metadata, Boolean isChecking)
   at System.Windows.Freezable.FreezeCore(Boolean isChecking)
   at System.Windows.Media.Animation.Animatable.FreezeCore(Boolean isChecking)
   at System.Windows.Media.Imaging.BitmapSource.FreezeCore(Boolean isChecking)
   at System.Windows.Freezable.Freeze()
   at Infragistics.Windows.Controls.AutoDisabledImage.CoerceSource(DependencyObject d, Object newValue)
   at System.Windows.DependencyObject.ProcessCoerceValue(DependencyProperty dp, PropertyMetadata metadata, EntryIndex& entryIndex, Int32& targetIndex, EffectiveValueEntry& newEntry, EffectiveValueEntry& oldEntry, Object& oldValue, Object baseValue, Object controlValue, CoerceValueCallback coerceValueCallback, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, Boolean skipBaseValueChecks)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.CoerceValue(DependencyProperty dp)
   at Infragistics.Windows.Controls.AutoDisabledImage.OnIsEnabledChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.PropertyChangedCallback.Invoke(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.UIElement.InvalidateForceInheritPropertyOnChildren(Visual v, DependencyProperty property)
   at System.Windows.UIElement.OnIsEnabledChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.Ribbon.RibbonButtonChrome.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.Controls.Primitives.ButtonBase.set_CanExecute(Boolean value)
   at System.Windows.Controls.Primitives.ButtonBase.UpdateCanExecute()
   at System.Windows.Controls.Primitives.ButtonBase.OnCanExecuteChanged(Object sender, EventArgs e)
   at ALMobile.WeakEventHandler`1.Invoke(Object sender, EventArgs e)
   at ALMobile.UI.ALMobileRoutedCommand.<OnCanExecuteChanged>b__1()
   at ALMobile.SynchronizationContextExtensionMethods.<>c__DisplayClass1.<RunInSync>b__0(Object ignored)
   at ALMobile.SynchronizationContextExtensionMethods.RunInSync[T](SynchronizationContext that, Action`1 action, T state, Boolean synchronous)
   at ALMobile.SynchronizationContextExtensionMethods.RunInSync[T](SynchronizationContext that, Action`1 action, T state)
   at ALMobile.SynchronizationContextExtensionMethods.RunInSync(SynchronizationContext that, Action action)
   at ALMobile.UI.ALMobileRoutedCommand.OnCanExecuteChanged()
   at ALMobile.UI.ALMobileCommandBinding.ObjectToWatch_PropertyChanged(Object sender, PropertyChangedEventArgs e)
   at System.ComponentModel.PropertyChangedEventHandler.Invoke(Object sender, PropertyChangedEventArgs e)
   at ALMobile.NotifyPropertyChangedBase.<>c__DisplayClass2.<OnPropertyChanged>b__0(String prop)
   at ALMobile.NotifyPropertyChangedBase.OnPropertyChanged(String property)
   at ALMobile.Common.ViewModels.WorkspaceViewModelBase`4.set_ErrorText(String value)
   at ALMobile.Common.ViewModels.WorkspaceViewModelBase`4.OnCurrentItemDetailsViewModel_PropertyChanged(Object sender, PropertyChangedEventArgs e)
   at ALMobile.Common.ViewModels.DetailViewModelBase.set_ErrorText(String value)
   at ALMobile.IErrorAwareExtensionMethods.HandleException(IErrorAware that, Exception x)
   at ALMobile.IErrorAwareExtensionMethods.TryOperation(IErrorAware that, Action operation)
   at ALMobile.Common.ViewModels.DetailViewModelBase.OnSave()
   at ALMobile.UI.ALMobileCommandBinding.<>c__DisplayClassa.<.ctor>b__7(Object s, ExecuteCommandEventArgs e)
   at ALMobile.UI.ALMobileCommandBinding.OnExecute(ExecuteCommandEventArgs args)
   at ALMobile.UI.ALMobileCommandManager.ExecuteCommand(ICommand command, Object parameter)
   at ALMobile.UI.ALMobileRoutedCommand.Execute(Object parameter)
   at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
