635
How to override default context menu in cell in edit mode?
I have a custom context menu bound to the DataRecordPresenter:
EventManager.RegisterClassHandler(typeof(DataRecordPresenter),
                DataRecordPresenter.ContextMenuOpeningEvent, new ContextMenuEventHandler(DRPContext));
But I also need it to open when I right-click on a cell that is in edit mode. Currently, the default clipboard menu comes up. What type should I use to override this with my custom context menu?
  • 27093
    I have been looking into your issue and can suggest creating a style for the XamEditor that your cell uses since it is actually the editor which is embedded in the cell and which enters edit mode. This way you will affect both states with one setting. E.g. if you have a DateTime value you can set the Field’s EditorStyle setting to:
    <Style TargetType="{x:Type igEditors:XamDateTimeEditor}">
        <Setter Property="ContextMenu" >
            <Setter.Value >
                <ContextMenu >
                    <ContextMenu.Items>
                        <TextBlock Text="Item 1 "/>
                        <TextBlock Text="Item 2"/>
                    </ContextMenu.Items>
                </ContextMenu>
            </Setter.Value>
        </Setter>
    </Style>
    Hope this helps. Please let me know if you require any further assistance on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
