Hi.
I use the attached excel with the fallowing code:
var wb = Workbook.Load(@"c:\S6.xls"); var ws = wb.Worksheets[1]; var value = ws.Rows[38].Cells[8].Value;
This read the Value out of Cell I39. In this Cell, there is the formula =G39/35 and when I open the xls direct in excel, there is the value 0.97.
When I read it with the code above, I get for the value {#NAME?}. Can someone help me, why this happens? - Thank you.
Best Regards, Thomas
I've downloaded the file and the code sample works fine for me. Can you share more details about the version of the controls you are using?
