I have an application that run without problem on many machines (including ones with XP home edition). That is except for one person with a netbook using windows XP. He gets the following error when the XamRibbon is initialized in the main program.
Message: Initialization of Infragistics.Windows.Ribbon.ButtonTool threw an exception.Data: System.Collections.ListDictionaryInternalSource: PresentationFrameworkStackTrace: at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator) at CarlinSoftware.ChartAnalysis.CSChartAnalysis.InitializeComponent() at CarlinSoftware.ChartAnalysis.CSChartAnalysis..ctor()TargetSite: Void RewrapException(System.Exception, System.Xaml.IXamlLineInfo, System.Uri)
Is there anything is all of your bugs reports that could explain what is happening and how to fix it?
HI,
This issue should be resolved in the latest service release.
If you have further questions regarding this issue, please let me know. Sincerely, Matt Developer Support Engineer
HI Rkcarlin,
We have a know issue regarding the XamRibbon running on an XP machine with Olive Green Theme applied.
I will create a case for this issue.
Turns out this is from running the green theme in windows XP.
