When I resize a window with a chart, the rendering is not smooth at all. The same happening on animating a chart.Like I am using charts in the XamTiles control, I had to turn off animation it is so bad.
I tried to set RefreshEnabled to false, did not help.
Gabor
Yes, I understand the problem with the layout rendering. I will try your suggested work around.
Thanks for your help.
The problem with animating the layout size of the chart is that it will have to recalculate everything for every tiny size change of the chart, and if you have a lot of data, this may mean that the animation can no longer be smooth. The reason why it has to recalculate things if you change the layout size is that it may need to orient the labels differently, or adjust margins, etc.
In contrast, if you adjust the render size of the chart while animation, this is purely a scaling effect that can be performed with the assistance of your graphics hardware, and does not affect the chart's layout at all.
If you can detect that an animation is starting/ending, you could:
Alternatively you could capture an image of the chart to take its place for the duration of the animation.
-Graham
Thanks Graham for the example.
The problem is that I don't want to set a fixed size for the chart. In the Tiles control I want to utilize the Min,Max,Normal views. I can set the ViewBox's Stretch to 'Fill' but that magnifies the chart instead of stretch.
Here's an example of animating the layout size of the chart vs. animating the render size of the chart.Layout is the top chart, Render the bottom.Here is the Xaml:
<Grid Height="800"> <Grid.RowDefinitions> <RowDefinition Height="400" /> <RowDefinition Height="400" /> </Grid.RowDefinitions> <Grid.ColumnDefinitions> <ColumnDefinition /> <ColumnDefinition Width="Auto" /> </Grid.ColumnDefinitions> <Grid x:Name="layout" Grid.Row="0"> <igChart:XamChart x:Name="chart1" Width="400" Height="400" > <igChart:XamChart.Axes> <igChart:Axis AxisType="PrimaryX" Unit="1000" /> </igChart:XamChart.Axes> <igChart:XamChart.Series> <igChart:Series ChartType="Line" DataMapping="Label = Label; Value = Value" DataSource="{Binding}" /> </igChart:XamChart.Series> </igChart:XamChart> </Grid> <Viewbox x:Name="render" Grid.Row="1" Stretch="Uniform"> <igChart:XamChart x:Name="chart2" Width="400" Height="400" > <igChart:XamChart.Axes> <igChart:Axis AxisType="PrimaryX" Unit="1000" /> </igChart:XamChart.Axes> <igChart:XamChart.Series> <igChart:Series ChartType="Line" DataMapping="Label = Label; Value = Value" DataSource="{Binding}" /> </igChart:XamChart.Series> </igChart:XamChart> </Viewbox> <Button x:Name="resize1" Grid.Row="0" Grid.Column="1" Content="Resize" > <Button.Triggers> <EventTrigger RoutedEvent="Button.Click"> <BeginStoryboard> <Storyboard> <DoubleAnimation From="{Binding ElementName=chart1, Path=ActualWidth}" To="0" Duration="0:00:01" Storyboard.Target="{Binding ElementName=chart1}" Storyboard.TargetProperty="Width" /> <DoubleAnimation From="{Binding ElementName=chart1, Path=ActualHeight}" To="0" Duration="0:00:01" Storyboard.Target="{Binding ElementName=chart1}" Storyboard.TargetProperty="Height" /> </Storyboard> </BeginStoryboard> </EventTrigger> </Button.Triggers> </Button> <Button x:Name="resize2" Grid.Row="1" Grid.Column="1" Content="Resize" > <Button.Triggers> <EventTrigger RoutedEvent="Button.Click"> <BeginStoryboard> <Storyboard> <DoubleAnimation From="{Binding ElementName=render, Path=ActualWidth}" To="0" Duration="0:00:01" Storyboard.Target="{Binding ElementName=render}" Storyboard.TargetProperty="Width" /> <DoubleAnimation From="{Binding ElementName=render, Path=ActualHeight}" To="0" Duration="0:00:01" Storyboard.Target="{Binding ElementName=render}" Storyboard.TargetProperty="Height" /> </Storyboard> </BeginStoryboard> </EventTrigger> </Button.Triggers> </Button> </Grid>
And here is the code behind:
public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); DataContext = new TestData(); } } public class TestDataItem { public string Label { get; set; } public double Value { get; set; } } public class TestData : ObservableCollection<TestDataItem> { public TestData() { Random rand = new Random(); double curr = 5.0; for (int i = 0; i < 10000; i++) { if (rand.NextDouble() > .5) { curr += rand.NextDouble(); } else { curr -= rand.NextDouble(); } Add(new TestDataItem() { Label = i.ToString(), Value = curr }); } } }
Hope this helps!-Graham
Gabor,
If you are talking about the chart size changing as you minimize and maximize tiles or animate the size of any container for the chart, you may want to instead consider setting a size for the chart and putting it in a viewbox or some similar approach. A render transform of the chart will always be much more efficient than a layout transform of the chart.
