We find when we copy text in grid and paste it in notepad. Grid will add some quotation mark.
The original text:FALSE RULE: RSUMR11 IF: APPWK(SRPTCOL,1) EQ " "
The pasted text:
"FALSE RULE: RSUMR11 IF: APPWK(SRPTCOL,1) EQ "" """Who know how to solve it?
Hello Shenjie,
I have been looking into your issue and tried to reproduce it with no success. I tried with the cell values and it worked as it should. Would you please describe your project and environment in more details or let me know if I have done something wrong so I am sure I replicate it correctly.
Looking forward to your reply.
Sincerely,
Petar Monov
Developer Support Engineer
Infragistics Bulgaria
www.infragistics.com/support
We are using 2010.1 xamDataGrid. And we don't enter the edit model. We just select a cell and copy it(Ctrl + C). I think it use ApplicationCommands.Copy.
Hi guys,
I have been looking into this and have managed to reproduce the issue using the quoted value Daniel suggested. I am going to forward this to our development team. In the meantime you can use this approach to overcome the behavior using the ExecutingCommand and ExecutedCommand events of the XamDataGrid:
private void grid_ExecutingCommand(object sender, ExecutingCommandEventArgs e)
if (e.Command == ApplicationCommands.Cut)
temp = grid.ActiveCell.Value.ToString();
public string temp;
private void grid_ExecutedCommand(object sender, ExecutedCommandEventArgs e)
Clipboard.Clear();
Clipboard.SetText(temp);
if (e.Command == ApplicationCommands.Copy)
Clipboard.SetText(grid.ActiveCell.Value.ToString());
Please let me know whether this works as well on your side.
Also I have not been able to reproduce the issue with a cell that does not have any quotation marks in it. Please verify if this is the case on your side as well.
Looking forward to your replies.
Hi Petar,
I take a look at your workaround. I think it might not satisfy our requirement.
We might copy multiple lines at same time. So how can we put all the data into clipboard?
Yes this was only a suggestion on how to overcome this yourselves. This is why I had logged this behavior with our developers. I have just checked on its progress and it appears it has already been fixed internally and will be available for downloading in the next Service Release. Here is a page from our website you can always check the upcoming release dates: http://ko.infragistics.com/support/documentation.aspx#ServiceReleases and here is a link for “My Keys and Downloads” page you can afterwards download it from: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
Hope this helps.
I use NetAdvantage 2010.3 now. But the problem is still there. Which service release I should use?
Hello Shengjie,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
