is there any way to change the theme, does it come with few theme to pick from like the grid?
The sample solution works great, but I can't get it to work if I put the Metro.xamDialogWindow.xaml file in another seperate project (and change the ResourceDictionary Source accordingly). Can you help me with this? I need to reference it from multiple projects in the same solution.
Thanks in advance.
Hey Matt,
Is this still a feature request or included in current release?
Vasu
HI,
I am following up on this thread.
If you need further assistance, please let me know.
Sincerely.
Matt Developer Support Engineer
The XamDialogWindow does not have a theme property like our other controls.
I will submit a feature request for this issue.
However you can style the XamDialogWindow.
Here are some help link on styling the XamDialogWindow
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=WPF_xamDialogWindow_Customize_Modal_Dialog_Window_Background.html
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=WPF_xamDialogWindow_Customize_the_Window_Header_Icon.html
http://help.infragistics.com/NetAdvantage/WPF/2010.2/CLR4.0/?page=WPF_xamDialogWindow_Using_xamDialogWindow.html
Sincerely, MattDeveloper Support Engineer
