840
Column Header Wordwrap
Hi
Is it posssible to restyle the header section to cater for word wrap on field names?
My dataset is not fixed so modifying entries in the FieldLayout.Fields in xaml is not an option.
Assuming the word wrap is possible, what property to I need to set in the code behind?  I'm also assuming the header section would need to be re-styled (using a textblock for example), just not sure where to "stick it".
thanks
Paul Eden
By the way.. .your auto-complete for the post tags is the most akward i've seen todate - can't you lose it?
