905
Summary tooltip
There is a tooltip on the summary labels like "FieldName: 1,200 USD". Is there a change to show the tool tip like "FieldLabel: 1,200 USD".
  • 27093
    Suggested Answer
    Hello ,
    I have been looking into your issue and have found a way for you to achieve your goal. What you can do is copy the original template from the DefaultStyles folder and change the Border’s  ToolTip binding like so:
    <!-- _________________________ SummaryResultPresenter ______________________________________ -->
    <Style TargetType="{x:Type igDP:SummaryResultPresenter}">
        <Setter Property="Padding" Value="1,1"/>
        <Setter Property="Template">
            <Setter.Value>
                <ControlTemplate TargetType="{x:Type igDP:SummaryResultPresenter}">
                    <Border
                  Background="{TemplateBinding Background}"
                  BorderBrush="{TemplateBinding BorderBrush}"
                  BorderThickness="1"
                  Padding="{TemplateBinding Padding}"
                  ToolTip="{Binding Path=SummaryResult, RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource MyCon}}">
                        <TextBlock Text="{Binding Path=SummaryResult.DisplayTextAsync, Mode=OneWay, RelativeSource={RelativeSource TemplatedParent}}"/>
                    </Border>
                </ControlTemplate>
            </Setter.Value>
        </Setter>
        <Setter Property="Margin" Value="0,0,0,2"/>
    </Style>
    and create a ToolTipConverter class implementing IValueConverter with a convert method like this one:
    public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
        if (value != null)
            return (value as SummaryResult).SourceField.Label.ToString() + ": " + (value as SummaryResult).DisplayText;
        else
            return value;
    Please let me know if you require any further assistance on the matter.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
