110
MenuTool and ButtonTool IsPressed state
When IsPressed, I want to change the Foreground to say Red.
I am able to get ButtonTool to work but I can't get MenuTool to work since there's no IsPressed DP.
I was able to get MenuTool response to IsOpen but that is only showing after IsMouseOver is false, some lower template is setting Foreground, I need to overrride that but I dont know where.
What is the best way for me to change text foreground to Red on MenuTool. Thanks.
  • 54937
    The MenuButtonArea is the element within the menu tool that renders the caption, image, etc. The template for this area has a trigger that when IsMouseOver is true, it changes the foreground; in theory this should also have a condition to not change it when its open. Since a template trigger will take precedence over a style setter, it is overriding your attempt to change the color. You will need to use a Style for the MenuButtonArea that has a trigger (since a local style trigger will take precedence over a template trigger).
    e.g.
    <Style TargetType="{x:Type igRibbon:MenuButtonArea}">
        <Style.Triggers>
            <DataTrigger Binding="{Binding Path=MenuTool.IsOpen, RelativeSource={RelativeSource Self}}" Value="True">
                <Setter Property="Foreground" Value="Green" />
            </DataTrigger>
        </Style.Triggers>
    </Style>
