i'm using an xamdatagrid inside a contentpane of a docking manager.
i assign a datacontext inside the code-behind's Window.Loaded event handler.
The grid is bound to a view model (clr-object).
The MaxWidth is set to positive infinity and the width to (auto).
When the window opens the grid's width is much more than would be necessary to display the columns.
I'd suppose the grid to auto-size depending on displayed column sizes but it seems it doesnt do so.
setting the grid max width or the grid.width is not acceptable because the grid shall fit to any size when the user resizes or (re)docks the content panes.
as a workaround i tried various ways to but i couldnt succeed to find one that's working.
can you help me?
ok, thank you!
Yes, there is a priority case created in our system with a reference number of CAS-54918-94VF7X. I will be getting back to you regarding the issue you raised through the case.
i have another question:
we have bought a license and should be registered to receive prior support.
is this request allready treated as prior-support? or what do i have to do?
thanx!
