185
Animate Row in XamDataGrid based on DataTrigger odd behaviour
I'm trying to animate a row in a XamDataGrid so that each time an item is updated (using a DataTrigger) the animation starts. The animation continutes until the end of the storyboard.
I've managed to get the animation to start when the first item is added but when a new item is added to the grid the animation stops. Then when another item is added, the animation which stopped continutes in another row.
eg.
row1 - animating for 10 seconds
after 5 seconds (i.e. before the 10 seconds is up)
row1 - animation has stopped
row2 - animation for 10 seconds
after a further 5 seconds
row1 - no animation
row2 - animation has stopped
row3 - animation for 10 seconds
row1 - no animation
row2 - animation FOR ROW1 restarted here from where it stopped!!!!*******
row3 - animation has stopped
row4 - animation for 10 seconds
I've tried a similar approach on a simple listbox and the animations work as expected. Below is the snippet of Xaml I'm using.
<Style TargetType="{x:Type igDP:DataRecordCellArea}">
<Setter Property="BackgroundHover" Value="{StaticResource GridHoverBackground}"/>
<Setter Property="BackgroundSelected" Value="Transparent"/>
<Setter Property="BackgroundActive" Value="Transparent"/>
<Setter Property="Background">
<Setter.Value>
<SolidColorBrush Color="Transparent" />
</Setter.Value>
</Setter>
<Style.Triggers>
<DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Record.DataItem.UpdatedAt, Converter={StaticResource IsNotNullToBooleanConverter}}" Value="True">
<DataTrigger.EnterActions>
<BeginStoryboard>
<Storyboard>
<ColorAnimationUsingKeyFrames Storyboard.TargetProperty="Background.Color" RepeatBehavior="1x" FillBehavior="HoldEnd" Duration="0:0:18">
<ColorAnimationUsingKeyFrames.KeyFrames>
<LinearColorKeyFrame Value="Red" KeyTime="0:0:0" />
<LinearColorKeyFrame Value="Orange" KeyTime="0:0:4" />
<LinearColorKeyFrame Value="Yellow" KeyTime="0:0:8" />
<LinearColorKeyFrame Value="Green" KeyTime="0:0:12" />
<LinearColorKeyFrame Value="Transparent" KeyTime="0:0:16" />
</ColorAnimationUsingKeyFrames.KeyFrames>
</ColorAnimationUsingKeyFrames>
</Storyboard>
</BeginStoryboard>
</DataTrigger.EnterActions>
</DataTrigger>
</Style.Triggers>
</Style>
Is there anything that I'm doing wrong?
