I've started using the new xamDataTree control in my project and have a question regarding drag / drop. I've enabled drag / drop because I want my users to be able to order items within the tree. Taking an example, let's say I have the following items in my tree:
- ParentNode NodeA NodeB NodeC NodeD
If I drag NodeA between NodeC and NodeD, the DropTarget property of TreeDropEventArgs will give me NodeD. If I drop after NodeD, the DropTarget is still NodeD.
In this example, how do I tell whether the DragSource was dropped before or after NodeD?
Many thanks,
Gary.
This issue has been fixed in the latest service release for NetAdvantage for WPF.
This service release is available under your account at the Infragistics Website. To download the service release, log in to ‘My IG’ and select ‘Keys & Downloads’. Select the NetAdvantage tab and then click on the product name. The available service releases should now be listed on the page underneath the tab control.
Please let me know if you have any further questions or concerns about this matter.
Ok, great !
Thanks for your answer. I'm waiting for the release.
This issue has been fixed internally and is scheduled to be made available in the next service release. This service release is currently scheduled to be released on December 20.
I'm going to create a private case for you so that you can track the development issue and also be notified when the service release is available.
I have exactly the same problem !
Is a bug fix available ? Have you found a workaround ? Please provide more informations.
Hello Gary,
I've discussed this with the development team and this has been determined to be a development issue. I have logged this with an ID of 58577.
I'll be providing more information through a case so that you can track the issue and be notified when a fix is available in a release.
