660
Problems with binding to DataView while styling fields
 Hello everyone!
I've faced a really strange problem with data-binding. The grid is bound to a DataView. I've declared some Field-s in the grid. And the field has the CellValuePresenterStyle property set in its settings.
Also, there is a textbox and a textblock, which are bound to a single (e.g. first) row of that DataView. The Text property of the textBox and the textBlock is bound to the field named 'Name'.
If a user edits text in the TextBox, the Name field is updated, so the textblock and the grid should be updated as well. But I only get the TextBlock updating as needed. The value of the needed cellin the grid is updated only after I scroll down the grid a lot and then return back, or after sorting, or after some other actions which apparently force the grid to update that cell.
But if i don't use the style to represent a cell's value, binding works fine.
Could someone please explain me what's wrong and how can I use styling and binding at the same time?
Here's some code:
<ig:XamDataGrid x:Name="xamDataGrid1"
                            GroupByAreaLocation="AboveDataArea"
                            DockPanel.Dock="Bottom"
                            Background="#FFFFFFFF" >
 <ig:XamDataGrid.FieldLayouts>
              <ig:FieldLayout Key="View1">
                <ig:FieldLayout.Fields>
                     <ig:Field Name="NameField" Label="Name" >
                    <ig:Field.Settings>
                      <ig:FieldSettings
                        AllowEdit="False"
                        CellWidth="80"
                        LabelWidth="80"
                        CellValuePresenterStyle="{StaticResource NameFieldStyle}"
                        CellMaxHeight="20"/>
                    </ig:Field.Settings>
                  </ig:Field>
                </ig:FieldLayout.Fields>
</ig:XamDataGrid>
<Style x:Key="NameFieldStyle" TargetType="{x:Type ig:CellValuePresenter}">
    <Setter Property="Template">
      <Setter.Value>
        <ControlTemplate TargetType="{x:Type ig:CellValuePresenter}">
            <TextBlock
              Text="{Binding Path=DataItem.Name}"
              VerticalAlignment="Center"
              Foreground="#FF151C55"
              Margin="5,0,0,0"/>
          </ControlTemplate>
        </Setter.Value>
      </Setter>
    </Style>
[Edit] One more thing: If I use DynamicResource instead of StaticResource - the style's not applied at all.
