Is there a filtering option anywhere in XamDataTree?
Ordinary TreeView has TreeView.Items.Filter, but I couldn't find anything like that here.
Thanks in advance.
7853.DataTreeFiltering_LAD.zip
I reworked the samples below. This may be helpful.
Update: I was able to create a RowFilter based on this Link: http://ko.infragistics.com/help/wpf/xamdatapresenter-add-filter-conditions
Thank you Infragistics :-)
How can I apply multiple filters to the same FieldName?
When I commented out the code below the view is blank.
Michael
Snippet:
private void ButtonBaseOnClickFilter(object sender, RoutedEventArgs e)
//// this.xtgBlotter.FieldLayouts[0].RecordFilters.Add(GenerateRecordFilter("CurrencyPair", ComparisonOperator.Contains, "USD"));
this.xtgBlotter.FieldLayouts[0].RecordFilters.Add(GenerateRecordFilter("CurrencyPair", ComparisonOperator.Equals, "CAD/JPY"));
private RecordFilter GenerateRecordFilter(string fieldName, ComparisonOperator comparisonOperator, string key)
var recordFilter = new RecordFilter { FieldName = fieldName };
var comparisonCondition = new ComparisonCondition(comparisonOperator, key);
recordFilter.Conditions.Add(comparisonCondition);
recordFilter.Conditions.LogicalOperator = LogicalOperator.Or;
return recordFilter;
Based on this link, it was added in 15.1.
http://ko.infragistics.com/community/blogs/blagunas/archive/2015/04/13/what-s-new-in-infragistics-wpf-15-1.aspx
Please provide a working example in code.
Infragistics Team,
"At this time the only way to do this is to apply filtering on the collection used for the ItemsSource"
We are using version 15.2, if there a more direct way to apply a filter? Same behavior as provided by Infragistics in the grid layout, but executed in code.
We are customize the default filter and need to be able set this in code.
Can you provide a working example based on this link?
Citigroup
Scratch my last post. I just understood what the line was for and I was able to get the filtering to work through the view model. Thanks again!
