When I issue the command:
XamScheduleDataManager scheduleDatamanager = new XamScheduleDataManager()
I receive System.ArgumentException: "Token not found.\r\n}Parameter:id"
Also, when I run the WPF XamFeatureBrowser4 Startup Solution and select Create xamSchedule in XAML or code-behind I get the same error.
I am running InfragisticsWPF4.Controls.Schedules.v10.3.
thanks, Ken
Hello Ken,
Just to let you know that we include this fix in to the latest service release that it ready for download.
Let me know if you have any further questions.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
We was able to identify this issue and confirm that was recently fixed internally in our system and should be published in our next service release. I have created a case for you CAS-55589-WN8G1Q, in order to get notified when the service release is published.More details about the planed service release dated you can find here:http://ko.infragistics.com/support/documentation.aspx#ServiceReleases
Hi Ken,
I was not able to reproduce this behavior. Can you send a little more information about the operating system, .NET framework version, regional settings and time zone that you are using?
Diyan Dimitrov
