I'm using a few xamdatagrids in my application and I'm restyling the SummaryResultPresenter to have a button to allow the user to accept some computed values using a custom calculator. However, I also want to make use of the default row summaries that ship with the grid (sum, min, max, etc) in some other columns on the grid, but they show up as a button obviously because they take the custom style I've done for the other field.
I saw another thread saying that the grid does not support setting a style using a key for a summary definition. My question is if there are any workarounds to this, since I really want to be able to have a couple different styles here? Thanks.
Hello Brian,
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Sincerely,Petar MonovDeveloper Support EngineerInfragistics Bulgariawww.infragistics.com/support
I have been looking into your issue and can agree whit what you have read since there is no property to allow you access to specified Field’s SummaryResultPresenter. I am no completely sure what exactly you are trying to achieve, but I can suggest you do not remove the original functionality simple add a visual state of sort that would be triggered only if needed. If you could describe in more details your scenario and/or upload a sample project I’d be glad to assist you along the way.
Hope this helps.
Sincerely,
Petar Monov
