I want to get the GroupByRecord (and his record child) of an HeaderRecordArea.
I don't find how to get this (I try with recursive function FindParent (FrameWorkElement) and VisualTreeHelper function and no GroupByRecord is Found).
Is solution exist ?
Thanks in advance,
Alex.
Hi Sam,
Has indicated in this forum that's doesn't work with grouping (is grouping check/uncheck in header check / unchek ALL record and not only childs record in the groups we'r click !)
I don't see how can do this fonctionnality, that why I witch to know how detect childs record of an header in groupby !
Hello Alex,
With the sample that was included in the forum post I provided you could group the records, and click on the checkBox located on the header record which had the functionality to check/uncheck its child records.
If it doesn't work for you, please submit a small sample that you have implemented with checkboxes and I review it and make suggestions.
Thank you,
Sam
Thanks Sam,
But It's doesn't give me the response of my question (and this exemple doesn't take groupby record when click on header prefix area Checkbox),
How could't I get the structure of any groupby with each children record and his Header witch contain my checkBox (or another control) ?
Thanks !
Alex,
You can see how this is implemented in the following blog post by Josh Smith, where he binds the CheckBox to a IsSelected property of the underlying item.
http://blogs.infragistics.com/blogs/josh_smith/archive/2008/09/04/adding-checkboxes-to-the-record-selectors-in-xamdatagrid.aspx
Sam,
Some explications :
I have for example an ObservableCollection where Items has a bool property.
I Bind this property on checkbox recordheader => It's ok,
But when I click on the CheckBox in Header, I want to check / uncheck all checkbox in recordheader with the respect's grouping.
