The users of our application are getting this error after sometime without using the application. In the stacktrace I see that its the infragistics grid the one generating the exception.
Do you have any idea what can be causing this? I am not able to reproduce it myself but I have the logs with the stacktrace and always is the same...
I paste the stacktrace. Any help would be more than welcomed.
Unhandled Exception, Exception='System.InvalidOperationException: Internal error: internal WPF code tried to reactivate a BindingExpression that was already marked as detached. at System.Windows.Data.BindingExpressionBase.SetStatus(BindingStatus status) at MS.Internal.Data.ClrBindingWorker.SetStatus(PropertyPathStatus status) at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.OnDependencyPropertyChanged(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.OnSourceInvalidation(DependencyObject d, DependencyProperty dp, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyPropertyKey key, Object value) at Infragistics.Windows.DataPresenter.DataRecordCellArea.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.TreeWalkHelper.InvalidateOnInheritablePropertyChange(FrameworkElement fe, FrameworkContentElement fce, InheritablePropertyChangeInfo info, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at System.Windows.Controls.ContentPresenter.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.RecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.DataPresenter.DataRecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.ConnectContainerToItem(ContainerReference cr) at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.RecyclingGenerator.GenerateNext(Boolean returnNullIfAlreadyRealized, Boolean& isNewlyRealized) at Infragistics.Windows.Virtualization.RecyclingItemContainerGenerator.GenerateNext(Boolean& isNewlyRealized) at Infragistics.Windows.DataPresenter.GridViewPanelNested.GenerateRecordPresenters(Size adjustedConstraint, Boolean topFixedRecordsOnly, Boolean bottomFixedRecordsOnly, Int32 rootTopFixedAdjustment, HeaderPlacement headerPlacement, Int32 maxRecordsToGenerate, Record& topRecordDisplayed, Record& lastRecordDisplayed, FieldLayout& lastFieldLayout, Int32& highestItemIndexProcessed, Int32& numberOfRecordsGenerated) at Infragistics.Windows.DataPresenter.GridViewPanelNested.MeasureOverride(Size availableSize) at System.Windows.FrameworkElement.MeasureCore(Size availableSize) at System.Windows.UIElement.Measure(Size availableSize) at System.Windows.ContextLayoutManager.UpdateLayout() at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg) at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork() at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks() at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget) at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter) at System.Windows.Threading.Dispatcher.Invoke(DispatcherPriority priority, Delegate method, Object arg) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.Run() at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at MorganStanley.IED.CubaConcord.App.Main() in m:\dev\ied\cuba\3.4.0\src\IED.CubaConcord\obj\Debug\App.g.cs:line 48' (App.App)
Hello Paul,
Thank you for your post. I have been looking into it, but since this is not a known issue, I am not able to reproduce it on my side, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
We have the same issue are there any solutions for this? This seemed to happen after a windows update.
Paul
Was this issue resolved? It would be nice if you could post the results to this thread. We are noticing the same error and would like to know if there is a fix/workaround.
Koushik
Hi Vlad,
Thanks for looking into it.
I can give you further details, we have a background thread that comes with notifications (i.e changes in the data displayed by the grid, adding new rows, removing rows from the bounded collection). Also this requires resorting sometimes. For this I do the resort in the InitializeRecord event and call e.Record.RefreshSortPosition().
Yesterday I commented this in the application and left the old one (with the refresh sort position uncommented) and the new one with the function commented and the old application crashed but the new one didnt.
We really need a solution for this because we need to show on the top the the latest updated records.
Federico
I've created a support ticket for you (CAS-56440-WDZ6W7) and will update you on e-mail when I have more information on this issue.
