I can't seem to get my child nodes to display. I have two classes, ReportSet and Report. ReportSet contains a binding list of Report.
I have my node layouts defined in the GlobalNodeLayouts like in the online documentation A first chance exception of type 'System.Reflection.TargetParameterCountException' occurred in mscorlib.dllSystem.Windows.Data Error: 8 : Cannot save value from target back to source. BindingExpression:Path=Node.IsExpanded; DataItem='XamDataTreeNodeControl' (Name=''); target element is 'ExpansionIndicator' (Name='ExpansionIndicator'); target property is 'IsExpanded' (type 'Boolean') TargetParameterCountException:'System.Reflection.TargetParameterCountException: Parameter count mismatch. at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture) at System.Reflection.RuntimePropertyInfo.GetValue(Object obj, Object[] index) at Infragistics.Controls.Menus.NodeLayout.ResolvePropertyInfo(Object data) at Infragistics.Controls.Menus.NodesManager.EnsureDataManager() at Infragistics.Controls.Menus.NodesManager..ctor(Int32 level, NodeLayout nodeLayout, XamDataTreeNode parentLayoutNode) at Infragistics.Controls.Menus.XamDataTreeNode.get_ChildNodesManager() at Infragistics.Controls.Menus.XamDataTreeNode.get_HasChildren() at Infragistics.Controls.Menus.XamDataTreeNode.IsExpandedChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at MS.Internal.Data.PropertyPathWorker.SetValue(Object item, Object value) at MS.Internal.Data.ClrBindingWorker.UpdateValue(Object value) at System.Windows.Data.BindingExpression.UpdateSource(Object value)'
<ig:XamDataTree.GlobalNodeLayouts><ig:NodeLayout Key="SetLayout" TargetTypeName="ReportSet" DisplayMemberPath="Name" /><ig:NodeLayout Key="ReportLayout" TargetTypeName="Report" DisplayMemberPath="ReportName"/></ig:XamDataTree.GlobalNodeLayouts >
What i'm getting is the parent nodes, with expander icons beside them, but when I click on the expander nothing happens. Looking in the output I see this exception was raised:
Any idea whats happening here?Can the child items be BindingLists or do they have to be ObservableCollections?
Thank you!
I'll check it out as soon as I'll be able to download the update.
Hello DrorCohen,
There was a fix addressing this issue in the February Service Release of NetAdvantage v10.3. If you get the latest Service Release from your "My IG" page off the main Infragistics website, then you should resolve this issue.
The reference number for this Development Issue is 61319.
Hi, I'm also having a similar problem since my object also implements the IDataErrorInfo interface in the same way. Did you guys find any solution to the problem?
Shaboboo, I will log this with our developers and follow up with you in a private support case.
Thanks for the sample. I have finnaly managed to track down the source of the error. My data objects inherit from a base class that implements IDataErrorInfo, and overrite the string this[string columnName] method. When it doens't overwrite the base method everything works fine.
I can work around this, but I have attached a sample with this error anyways.
thanks
