public string ItemID { get; set; } public string UPC_SKU { get; set; } public string StockingUM { get; set; } public decimal Price { get; set; } public decimal Weight { get; set; } public ObservableCollection<InvCategory> AttachedCategories { get { return _categories; } set { _categories = value; } }public ObservableCollection<InvDocument> Documents { get { return _documents; } set { _documents = value; }}public ObservableCollection<string> Tags { get { return _tags; } set { _tags = value; }} public InvItem() { } } The InvItem class is stored in an ObservableCollection<InvItem> which is populated with a call to my database. I then bind the collection to my XamDataGrid. Allowing the XamDataGrid to AutoGenerate Fields and Layout, it discovers the Hierachical data structure between ObservableCollection<InvItem> and it's child collections, <AttachedCategories>, <Documents>, etc, But, I am trying to build a manual field layout very similar to the 'Record Layout Customization' sample in the Feature Browser. For the child collections, I would like to use a ComboBox or XamComboEditor, both of which I have been able to embed in the XamDataGrid, but I have been unable to bind either to the child collections. Any help would be greatly appreciated. Rob
<Documents>, etc,
Rob
Hi Marianne,
Thank you for your response. Unfortunately, it has been nearly a year between my original post and your response. I have long since moved on from that project and no longer remember the details involved.
Thanks anyway.
Hi Rob,
I’m following up on your forum post. I hadn’t heard back from you with any further description of your requirements.
Is there anything further that I can help you with regarding this issue?
If so, please feel free to contact me.
I've been working on your question but I could use some clarification.
You mentioned embedding a XamComboEditor into the xamDataGrid but you also mentioned the “Record Layout Customization” sample which is causing me a little confusion in the direction you are going.
If you want to show hierarchical data in your grid, you may just need to define multiple layouts.
If you are trying to define a column within the parent row as a XamComboEditor to show a collection within the InvItem then you will need to add an unbound field for the XamComboEditor.
I’m working on a sample that will show you both scenarios but it would be helpful if you could clarify your requirement in the UI.
