490
how to specify custom templating mechanism to a field template inside a xamdatagrid
how to specify custom templating mechanism to a field template or if it is possible to do as follows to specify stackpanel?
<my:XamDataGrid Height="103" Margin="12,25,92,0" Name="xamDataGrid1" VerticalAlignment="Top" DataSource="{Binding Path=.}">
<my:XamDataGrid.FieldLayoutSettings>
<my:FieldLayoutSettings x:Uid="my:FieldLayoutSettings_1" AutoArrangeCells="Never" AutoGenerateFields="False" />
</my:XamDataGrid.FieldLayoutSettings>
<my:XamDataGrid.FieldLayouts>
<my:FieldLayout x:Uid="my:FieldLayout_1">
<my:FieldLayout.Fields>
<StackPanel><Label>Hello Description</Label><my:Field Name="appdesc" /> </StackPanel>
<my:Field Name="appdesccode"/>
</my:FieldLayout.Fields>
</my:FieldLayout>
</my:XamDataGrid.FieldLayouts>
</my:XamDataGrid>
  • 8576
    Hi Vairam -
    The element that presents Field data is called the CellValuePresenter.  So to re-template the contents of a Field you would need to create a Style for the CellValuePresenter that sets a new Template with the elements of your choice, and then set that Style on the Field.Settings.CellValuePresenterStyle property.
    If you search the forum for CellValuePresenter you will see numerous posts that show how to do this.
    Joe
