35
Using MVVM light toolkit with Menuitem
We are using t he MVVM light toolkit and want to attach a command to a menu item.
I've created the following XAML the event doesn't appear to be triggered.
Does anyone have any pointers?
Many thanks,
<ig:XamMenuItem Header="New" Height="33" HorizontalAlignment="Left"  Name="xamMenuItem1" VerticalAlignment="Center"  >
                <i:Interaction.Triggers>
                    <i:EventTrigger EventName="Click">
                        <cmd:EventToCommand Command="{Binding NewContactCommand, Mode=TwoWay}" />
                    </i:EventTrigger>
                </i:Interaction.Triggers>
</ig:XamMenuItem>
  • 215
    I've had the same problem and fixed it.  It seems the XamMenuItem isn't aware of it's DataContext.  Try setting the data context on the XamMenuItem.  Here is my example:
                              <ig:XamMenuItem
                                    DataContext="{Binding RelatedPriorityGrid, Source={StaticResource Locator}}"
                                    Name="AddPriority"
                                    Header="Ajouter item sélectionné à mes priorités"
                                    IsEnabled="{Binding CanAddPriority}">
                                            <cmd:EventToCommand PassEventArgsToCommand="True" Command="{Binding AddPriorityCommand}" />
                                        </i:EventTrigger>
                                    <ig:XamMenuItem.Icon>
                                        <Image Source="Resources/Add.png"/>
                                    </ig:XamMenuItem.Icon>
                                </ig:XamMenuItem>
    Hope this helps!
    Yohan
  • 81
    Because the XamMenuItem doesn have a Click event defined since it's not inherited from ButtonBase.  If you use MouseRightDowninstead of Click it will work. MouseLeftDoen won't work becuase it is intercepter by XamMenuItem.
    I think to use the left button you need to wire the event handler and invoke the command in the code behind.
