665
Limiting Tile width
I've got a ContentPane that contains a XamTilesControl with TileLayoutOrder set to UseExplicitRowColumnOnTile.  One of the Tiles contains an ItemsControl that lays out the items horizontally using a WrapPanel.  The behavior I'd like is for the Tile to expand horizontally until reaching the XamTilesControl visible dimensions, at which point a new row would start.  However, that's not what happens.  What I end up with is only 1 row is created for the items and it extends far beyond the visible dimensions of the XamTilesControl.  A horizontal scroll bar is created so I can scroll to view all items in the list.
Is there a way to achieve the layout I'm looking for?  I'm assuming the problem is that everything is auto-sized, so there is no rule in place to prevent the ItemsControl from expanding as far as it needs to so that all items fit.  I've fussed with TileConstraints but I need a more dynamic solution.
Thanks!
