This is the exception I get when attempting to set EditorStyle in Field.Setting instance:
System.ArgumentException was unhandled by user code
Message="FieldSettings.EditorStyle's TargetType setting can only be null or a type that derives from ValueEditor or is a base class of ValueEditor, XamNumericEditor is invalid.\r\nParameter name: FieldSettings.EditorStyle"
Source="InfragisticsWPF3.v10.3"
ParamName="FieldSettings.EditorStyle"
StackTrace:
at Infragistics.Windows.Utilities.ValidateTargetTypeOfStyle(Style style, Type targetType, String propertyName)
at Infragistics.Windows.DataPresenter.FieldSettings.ValidateEditorStyle(Object value)
at System.Windows.DependencyProperty.IsValidValue(Object value)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at Infragistics.Windows.DataPresenter.FieldSettings.set_EditorStyle(Style value)
at EMS.Controls.Dictionary.Utility.FieldLayoutFactory.CreateFieldsLayout(ResourceDictionary resources, IEnumerable`1 lstFieldProps, IList`1 sortedFields) in C:\dev\LUT600 2.1.1\OCC600\Source\Libraries\ControlsDictionary\Factories\FieldLayoutFactory.cs:line 570
at EMS.Controls.Dictionary.Utility.FieldLayoutFactory.CreateFieldsLayout(ResourceDictionary resources, DataPresentationProperties dataPresentationProps) in C:\dev\LUT600 2.1.1\OCC600\Source\Libraries\ControlsDictionary\Factories\FieldLayoutFactory.cs:line 605
at OCC600.BeaconManager.Views.SolutionsView..ctor(SolutionsViewModel model, DataPresentationProperties fieldProps, UniqueNameAlias id) in C:\dev\LUT600 2.1.1\OCC600\Source\BeaconManager\BeaconManager\Views\SolutionsView.xaml.cs:line 49
at OCC600.BeaconManager.BeaconAlertPresenter.ShowView(Object arg) in C:\dev\LUT600 2.1.1\OCC600\Source\BeaconManager\BeaconManager\BeaconAlertPresenter.cs:line 270
at OCC600.BeaconManager.BeaconAlertPresenter.Initialize(Boolean useDefault) in C:\dev\LUT600 2.1.1\OCC600\Source\BeaconManager\BeaconManager\BeaconAlertPresenter.cs:line 148
at OCC600.BeaconManager.BeaconAlertPresenter..ctor(IUnityContainer container) in C:\dev\LUT600 2.1.1\OCC600\Source\BeaconManager\BeaconManager\BeaconAlertPresenter.cs:line 82
at OCC600.BeaconManager.Module.Initialize() in C:\dev\LUT600 2.1.1\OCC600\Source\BeaconManager\BeaconManager\Module.cs:line 17
at Microsoft.Practices.Composite.Modularity.ModuleLoader.Initialize(ModuleInfo[] moduleInfos)
InnerException:
Style being used is defined as follows:
<Style x:Key="LeftAlignedXamGridIntegerEditorStyle" TargetType="{x:Type igEd:XamNumericEditor }">
<Setter Property="VerticalAlignment" Value="Center"/>
<Setter Property="FlowDirection" Value="LeftToRight"/>
<Setter Property="HorizontalContentAlignment" Value="Left"/>
</Style>
What should I do?
TIA.
Thanks again.
Never mind. Build clean and rebuild fixed problem.
