410
Show SortIndicator without sorting
is it possible to show the SortIndicator for a specific column without actually sorting this column?
Thanks!
  • 27093
    Hello Christoph,
    If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
    Sincerely,
    Petar Monov
    Developer Support Engineer
    Infragistics Bulgaria
    www.infragistics.com/support
  • 27093
    Suggested Answer
    Hello Christoph,
    I have been looking  into your requirement and even though this is not supported I have managed to find a way for you to achieve this. What you can do is take a copy of the original template for the LabelPreesnter from the DefaultStyles\DataPresenter folder DataPresenterGeneric_Express.xaml file  (default installation path: C:\Program Files (x86)\Infragistics\NetAdvantage 2010.3\WPF\DefaultStyles\DataPresenter ) and add a Trigger to the ControlTemplate.Triggers node similar to this one:
    <Trigger Property="SortStatus" Value="NotSorted">
        <Setter TargetName="SortIndicator" Property="Opacity" Value="0.8"/>
        <Setter TargetName="SortIndicator" Property="Visibility" Value="Visible"/>
    </Trigger>
    Please let me know if you require any further assistance on the matter.
    Sincerely,
    Petar Monov
