1825
Application Crashes after Reordering Columns and Exporting to Excel
I am using InfragisticsWPF3.DataPresenter.ExcelExporter.v10.2 and we have a  XamDataGrid with the Export to Excel feature. After I sort a particular column and then Export to Excel the application Crashes with the exception
"Field named  was not found in data source: Record\r\nParameter name: FieldName"
I have the following code for the Export to Excel
private void ExecutedXLExportGridCommand(object sender_, ExecutedRoutedEventArgs e_)
      if (!(e_.Parameter is string))
        return;
      switch (e_.Parameter as string)
        case "MainGrid":
          ExportGrid(ux_gridStudyContent);
          break;
    private static void ExportGrid(DataPresenterBase grid_)
      string _temporaryFile = string.Format("{0}\\{1}_PnLLink_Export.xls",
                                            Environment.GetFolderPath(Environment.SpecialFolder.InternetCache),
                                            Guid.NewGuid().ToString("N"));
      var _exporter = new DataPresenterExcelExporter();
      _exporter.Export(grid_, _temporaryFile, WorkbookFormat.Excel97To2003);
      Process.Start(_temporaryFile);
The Export to Excel works fine when I do not sort any column
  • 2677
    Do you perhaps have a sample application that demonstrates this bug.  I tried my own sample and exported the grid and can't seem to reproduce the problem.  I have just a plain grid bound to a datasource which is a datatable for brevity.  Please either send a sample or exact specifications on the datasource type, if you are manually generating FieldLayouts etc.  Your xaml source would be great because then I could see all the properties that you are setting.
    Once I have more information on the issue and am able to see it occur, I will be able to fix it or send it off to development for a closer look.  Thanks and hope to talk to you soon.
