var printItem = new MenuItem { Header = "Print..." };printItem.Click += (sender, e) => {
var reportSection = new EmbeddedVisualReportSection(this); var report = new Report(); report.Sections.Add(reportSection); report.Export(OutputFormat.XPS, @"c:\test.xps"); // Exports fine the entire grid. report.Print(); //throws CrossThread exception
};gridMenu.Items.Add(printItem);
What could be the reason?
We are bouncing back and forward. I have created different thread for different problem:
http://community.infragistics.com/forums/p/51097/267692.aspx#267692
I should say Microsoft PrintDialog not ReportDialog, in the link you provided.
Sam
Sorry, which "ReportDialog" are you reffering to?
Somehow my response is not showing in this thread. I am not sure if you received it somehow.
Earlier today I have commented that this issue appeared to me Microsoft related bug with ReportDialog as Andrew pointed out, and our Report class is using WPF ReportDialog.
As I stated PrintingDialog issue has been resolved for now, but I described the different issue about how grid is printed or exported to XPS file. It is not related to printing since exporting to xps does the same thing. Please see couple posts above.
